A couple questions
ThunderChicken1982 Offline
does anyone have any information on where to get the air inlet bolt/thing (not sure exactly what it's called, but it's on the back end of the exhaust manifold and has a nut with a small hole in the plug) the part itself is most likely re-usable in an emergency, but when i was looking for other parts today i was told that it has been discontinued by ford, and the suggestion the guy at napa gave me isn't what i need, because it will most likely result in my turbo blowing again. (whoever owned this car before me did not do a very good job of keeping it up or putting things back together correctly) any help or info would be greatly appreciated. Thanks!
Geoff Krempa
karnage Offline
That would be for the egr tube.You could either plug it with a 1/2 pipe plug or find someone with the fitting thats needed.They are easy to find in the sale section.
there is also a small hole in the plug and a line running to it. is the plug you're refering to the same? thanks!
Geoff
B_Lieder Offline
Is this what your talking about?? If it is, then its what karnage said. If you need another one i'm sure you can get one in the parts for sale section.
Hope this helped
Bill Lieder
1988 TC stock until summer
Bill L
