blueoval
Jun 2004
AZLE, TX
The front of the a/c compresser came off, not the whole pulley just the front piece.
The pulley is spinnig but I can now see the end of the shaft and i isn't spinning. Anybody have in any ideas?
Speed Kills Save A Life Drive A Chevy.
Sounds like the clutch assy came off.
TurboCoupeTurbo
Apr 2004
Miami Beach, Fl, US of A
thats strange..strange indeed. i would recommend replacing the compressor, because if the assembly came off, it may have been caused by heat or a bad bearing. its just as easy to change it all and know for sure. btw you can use the ford fuel line disconnect to get the lines off the compressor.
turbo turbo
Turbo
Keith Nubel
Liberty Township, OH
The clutch should require a puller to remove. Is the bolt missing? But I agree, I think you clutch came apart.
85.5 TC 5 speed, Ranger Roller cam, 3" exhaust system, manual boost valve, large VAM, SVO PE computer, front mount Motorsport intercooler & sport grille, ported upper and lower intakes,flow matched injectors, ported E6 manifold, 245/45/17 wheels & Tires,140 mph speedo,Motorsport lowering springs, under restoration
1985 TC
blueoval
Jun 2004
AZLE, TX
Yeah i think its is the clutch that came off. The bolt is missing. Can I get a new compresor from the auto parts store?
tps87turbo
Feb 2003
Hammonton, NJ USA
Yes you can, but be prepared to spend a few bucks 'cause they are not cheap. & while you are doing that you should convert to R134a if you have't done it already.
Tony Sceia -
[This message has been edited by tps87turbo (edited 10-19-2004).]
PetzJC
Feb 2004
California, MD
The same thing happened to me way back when with my 85 XR7. All I did was install a new clutch assembly....
88 Silver T/C, original owner, 256,000 miles.
Loaded with everything except leather & auto trans.
K&N, Gillis, SVO roller #1, big SS valves, ported intake, head, & exhaust.
Bottom end & turbo original/untouched.
Polyurethane bushings throughout, Goodyear GT-HR 235/55R16's.
