A/C lines
SteveX82 Offline
I've given up on fixing/recharging my A/C anytime soon, so i've already taken off the compressor belt and am now looking to remove the entire condensor to save a bit of weight and free up some air-circulation space around the turbo. my question is......how do i disconnect those refridgerant lines? do i need a special tool of some sort. and yes, the system has already been discharged [Image: smile.gif] (even i'm not that stupid)
1987tc Offline
There is a disconnect tool you will need to get . It is round and wraps around the line and the fitting. You then push it against the fitting while pulling on the line. This will release the spring. You might want to get a set of these since the fuel lines also use the same type but diferent size of coupling.
Wes
1987 TC:
Hurst compition plus shifter,K&N cone,roller cam,custom single exhaust,Gillis valve,H&R springs,KYB shocks,struts and quads.
3.73 rear.
Tubular rear control arms and Kenny Brown trac kit brackets. soon to come, Installation of Caster camber plates and a custom built roll cage.
Linton Indiana
