88 Turbo Coupe won't idle correctly when warm.
LimaTee Offline
I installed plugs, plug wires, new cap & rotor, then got the timing set on my white bird today.
No change in how it runs.
It starts right up when cold, & runs fine for a while.
Once warm the idle goes south. If it is shut off when warm, it starts again, but will not idle.
After feathering the throttle for a couple of minutes to keep it running it begins to level out a bit. It idles roughly but doesn't die immediately like when first started warm.
It still seems to run down the road ok when warm, but dies at stop lights.
Any ideas where to look now for the problem?
It does have an exhaust leak...could that effect it that much?
Ron
The one part that never gets fixed on my cars is the nut that holds the steering wheel
squeeky Offline
can you check codes? maybe TPS setting and a base idle reset...
88 turbocoupe, gillis valve, k&n, short throw shifter,3" exhaust with magnaflows,Garrett(turbonetics) T3,AFPR,18lbs boost for now.....
Scott Mabe Offline
Also, maybe a vacuum leak.
1987 Turbo Coupe
1990 F-250HD 460ci
LimaTee Offline
I pulled the codes this morning & got a number 42 (oxygen sensor).
I didn't know that a faulty one of these could cause so many problems with idle etc, but it may explain why the plugs that I took out of it yesterday were so black.
Ron
42 does NOT mean a bad O2!!! 42 is a symptom code telling you the correctly functioning O2 has detected a rich condition that is outside the correction range of the long term fuel trim adaptives. Check fuel pressure to be sure it is in spec. Check FPR vac hose for smell of fuel or liquid gas indicating a blown / leaking diaphram.
Was the 42 a HARD code (koer test) or CM code?
LimaTee Offline
Wow Jeff, Thanks for explaining that one to me. The manual that came with my decoder simply said: "42= Exhaust Gas Oxygen Sensor: Voltage sensor always 'rich'(high value)-does not switch."
I talked to my brother this morning and he asked if my coolant temperature sender might be faulty because my temp. gauge has been crazy since I bought the car.
Do you agree that the coolant sender could cause the symptoms that I described above?
I bought both temperature sending units this morning to install, but will definitely check the fuel pressure and the FPR vac.hose (as soon as I figure out where it is located).
This was a KOEO test. I am not sure what a CM Code is.
Ron
Dan S Offline
CONTINUOUS MEMORY CODES (CM)
Continuous Memory Codes are issued
as a result of information stored
while the vehicle was in normal operation
during the last 40 starts. These codes are
displayed after the separator code 10.
These codes should be used for diagnosis
only when Key On Engine Off and
Engine Running Self-Tests result in pass
or "ok" code 11.
Dan S
1972 Ford F-100 SWB Styleside
Personally, I never replace any part without a complete diagnosis of the problem. It is possible ECT is bad, but I would check it first. Kind of a PITA to get to, but pull the 2 pin connector off and get probes from an ohm meter onto the 2 terminals. Engine cold should read 20,000 ohms or more. Engine at operating temp should read in the low 1000's ohm range. You can also monitor the voltage across the ECT while the car is running and warming up. At operating temp, you should get about .4V across the ECT.
LimaTee Offline
DUH.......
I looked through the entire book that came with the scanner looking for a mention of CM Code. They never used that abbreviation, but talked about continuous memory a bunch. I just never made the connection...
Ron
The temp sender for the gauge has nothing to do with the engine control module and vice versa Your temp gauge issue is a separate problem. If the temp gauge and the oil pressure and fuel level gauges go erratically, up and down together, the problem is a bad instrument voltage regulator (IVR) which is on the back side of the gauge pod
