NATO member RDOG has another post on here confirming that the 88-89 Ford Tempo valve cover breather is a direct fit/replacement for the 87-88 TC unit. I know most people go to the JY to pull one but for anyone who doesn't have a local yard can order brand new ones from RockAuto. Part # is FA1118 for the Motorcraft unit. This valve cover breather is slightly different from the stock 87-88 TC's but it does fit and it is also a lower profile (good for larger throttle bodies). I don't believe this comes with a new grommet but one can be ordered from RockAuto. Part #'s are Dorman 42049 or GV27
