The PE is considered the best because the 85.5-86 SVOs made the most HP. It will work but you need to check to see if any re pinning is necessary
Mike C
Sep 2005
Bellmore, NY
The PE was a plug & play in an 86 with the exception of the Premium fuel switch. That only required the grounding of 1 wire for premium fuel setting.
I found good info when I did mine switch. I chose the PE because of the ease of install.
Be prepared to pay around $ 200. for a PE if you find one.
.02
Mike C
86 5 speed TC black with MS spats and spoiler since 88, 3.73 8.8 since 89. Fresh rebuild at 240K with new Racer Walsh roller cam, 88 hood. All 3" exhaust w/3" performance cat. 13" Cobra brakes,SFC, Max/Motorsport C/C plates,adjustable lower control arms w/ double adjustable uppers. Konis & Eibachs.
Robert Camp
Jan 2006
Raleigh, NC
I'm under the impression the PE requires the large VAM also? Can someone confirm or deny!
Robert Camp
'86 Medium Regatta Blue TC, 5-speed, original owner.
tgriffith360
Aug 2007
cedar bluff, VA
O.K.,,need a little help,,,,,where do I get this large VAM
tgriffith360
Aug 2007
cedar bluff, VA
OK..little more help,,,,after spending hundreds on a SDS system for a stocker mustang 5.0,,,found out later that I could have just increased fuel pressure,,,lock down timing and pulled the module out of the distibutor that connected it to the computer so it couldnt move around and picked up nearly as much as spending $1200 for the SDS,,,,=I know this is a different critter where at one point dont need nearly as much fuel and then under higher boost conditions may need alot of fuel,,BUT is it possible to get nearly the same out of just turning up the pressure???
Walsted
Fort Worth, TX
I think you may want to do a search on LA3 swap. Or, read http://www.mikewalsted.com/tbird_LA3.html .
tgriffith360
Aug 2007
cedar bluff, VA
thanks,,those pin outs are helpfull,,,,not finding much on the net about these,,,
also,,,this is going to be an all out race car that will never see the street and have 110 octane fuel in at all times,,,,so how much of this wiring do I need,,,,such as the trans wires,,,its going to have a C4 ,,,,,,,I notice that they are wires to the boost control,,,,
also I notice a difference in a octane switch,,,is this different that a knock switch???
tps87turbo
Feb 2003
Hammonton, NJ USA
Quote:Originally posted by Pete D:
Quote:explain the blow thru on the Vam`s
The VAM is relocated after the turbo instead of before the turbo.
Pete.... Can u tell me hthe benefit of doing this? I never thought about doing that & am wonder what gains would be obtained from this change.
tgriffith360
Aug 2007
cedar bluff, VA
Im guessing with his explaination, the air coming in isnt restricted and Im guessing that air flow is better to the engine forcing it thru the VAM
Mike C
Sep 2005
Bellmore, NY
When I said plug and play on the PE I was referring to the wires. It would still need the large VAM & 35 # injectors. No changes to the pin out, which is what I was scared of! Just the Premium fuel switch to deal with.
.02
Mike C
