Is the head on the 86 TC the same as whats on the 88. Which is better?
Also, what about the bottom end, are they the same or is one better than the other?
88TC :5 speed swap,255 walbo fuel pump, 3" down pipe with 2 1/2"duals, Ported upper and lower intake, ported E-6, Kiben adjustable fuel pressure regulator,T-3 turbo,Forge BPV,Steeda Tri-x shifter,Autometer gauges,Racer Walsh stage #2 cam, Spec stage 3 clutch,Stinger FMIC
