Sluggo
May 2004
Huntingtown, MD., USA
[email protected] - 7.97@89 1/8th
The 26" ET Streets are a hit. 1.77 60' so far. I need to get a set of 28". 6700 rpm thru the traps and very little 1st gear. Can't wait to get my tranny parts back from Liberty.
Joe, I'll turn in a slip after next weekend.
Doug
88 TC / T5,4.56,Log,SC60,NPR,2277,MegaSquirt
turbo tom
Jun 2006
york, pa
So much for suspense! lol. Glad to hear they worked out. I think I'll go to a bias ply when mine are shot. Might be awhile at the rate I'm going
Speak softly and carry a ...errr really big turbo. 84 GT R.I.P 94 F250 Turbo Diesel
Nice going Doug.
86XR7auto
Mar 2003
Mt. Pleasant, MI. USA
Good Job Dougo...
Can you tell us the details, like boost, timing, and squeeze????
Coming up on the elevens...
Travis
Sluggo
May 2004
Only changes since last time being the timing +2*, n2o on a little longer, and the shorter et streets.
timing was 23* at the top
boost set to 22#'s
70 shot all the way down the track
still granny shifting @ 6300
I filled the tank with 93 last week and could only get 5 gal of 110 in it. Had to set the n2o off switch from 6k to 6700 after it fell on it's face on a [email protected] run. That run also had 2* less timing.
Will call the local speed shop in a few minutes and see if they have some 28/11.50-15's in stock. I need to get the bottle filled for next weekend also. Cecil will be 11.xx or bust. I have jets up to 150hp and I'm not afraid to use them if I have to.
Here's a question for the other stick drivers with a shift light. How much lower than your actual shift point do you set the shift light to? I had the light on at 5600 and shifted at 6300. Am I just that slow to react to it or is this normal?
Doug
AerobirdMotorsports
Dec 2004
Kelso, WA USA
Nice going! That's great MPH too.
You're a little slow on the shift light, rule of thumb is 500RPM before, you're at 700RPM.
turbo tom
Jun 2006
york, pa
I'll definatly take my camera to capture the flying parts....of course it'll probably be my parts! lol. Those are some great numbers. Keep chiseling away at it and before you know it,you'll be in the 11's.
