4.6 Conversion
23027 Offline
Was just curious as to why swapping a 4.6 into a turbocoupe is so unpopular? It's a bit of a better engine stock for stock, is it because the engine management is different, different wiring harness and computer etc?
87 Turbo Coupe
New Heart & Lungs as of 245,225km.
302 H.O Swapped.. Bolt ons.. Tremec 3550.. 4.10's.. 18's..
https://postimg.org/image/efv6lnn35/
All of the above!
EEC-IV vs OBDII
5.0TurboCoupe1988 Offline
plus, a 5.0 will make a lot more power than a 4.6 2v.
1988 TC 2.3/5-Speed, 148K
UglyBird85 Offline
I thought about taking my 4.6 out of my cobra when I totalled it and putting it in my 85 TC. I took the money from the insurance instead though. It probably would've been one of the nastiest TC's around though haha
---Justin
87 Burgundy TC 5spd. K&N Cone filter-Walboro 255HP-.60/.63 Garret T3-Gillis @ 18psi.
SHELF: NPR FMIC-Ford Racing 42# injectors-Tripminder-
The Shredder Offline
I'm still contemplating the 96-98 Mustang Cobra DOHC 4.6 swap into mine. Don't tempt me! Smile
88TC blue/blue, auto, loaded except leather, bone stock, 127K mi. - back in the TC game!
88TC white, converted 5 spd, K&N filter, Manual Gillis BV, 189K mi. SOLD :-(
UglyBird85 Offline
It'd be nasty. And most importantly, unique!!
Do it!!!
---Justin
Timmay Offline
Na if your gunna put a v8 into a TC hold off for a little while longer till a few punk kids wreck some 2011 stangs then get a new 5.0 and stuff it under the hood of a TC. In its N/A form it puts out more power then a supercharged 4.6l.
1988 Turbocoupe- RIP in a place without rust!
1978 Mercury Bobcat super clean-2.3T, t5 trans, 8.8 rear 3.73 gears 31 spline axles,255 walboro in-line,MBC,3 inch exhaust,4 wheel disc brakes,5 lug
EvillBird Offline
You would be better off with a used 03/04 Cobra engine. Easier to find and can handle just about anything you can toss at it.
1988 Turbo Coupe
2003 Mustang Cobra
23027 Offline
Definitely a worthy swap, the 4.6 sounds so bad ***. I always find the 5.0 a little more metallic sounding and has a bit less of a lull. Both unreal engines though.
5.0 plug-n-play (sort of) FTW
87 Turbo Coupe
methos Offline
After working at ATK, I grew tired of anything small block. Everytime I see a 302 in a car it just makes me think of how sad it is that they are using it. At one time, I was going to put a nasty 351C 4V with the closed chamber heads in the car. But the 2.3T just came back calling. 2v 4.6's are on the same level as the 302. 4v 4.6, 351C, or FE or not at all. Yeah, grew tired of the 385 series too. But that's my opinion.
Jason Schaffer
88TC - 5speed, all options but leather and sunroof
Mods: 3.73 Gears
Finally getting it back together.
