karnage
Mar 2003
Olympia, WA.
I need some sort of a wiring diagram how to install a 3G in my 84 TC.I have a alt harness from an 88 TC if needed.Also will a 3G work from an F-150???I I get one, should I grab the harness of the truck also??
84 TC with 88 hood LA-3 full 3" exhaust Rods header ported/polished big valve head schneider roller cam RW adj cam gear Kirban gillis at 20 # boost MSD ignition 255 lph Walbro full gauges
17 inch centerlines 944 front mount IC 80mm MAF
65mm tb-rotated intake on the way to 400HP
BJL
Williamstown, New Jersey
i grabed my alt form the parts store, remnaufactured form a 95 Mustang Cobra, 100 bucks. wnet to the u pul it yard and cut the alternator harness off a escort with the 3G low amp alt. the secort had about 3 feet of wire befroe it went the main harness, reason i chose an escort. follow the instructiosn and shoudl be done with in 2 hours, max
Brian Larkin
88TC 330,000 miles
Slightly Modified
karnage
Mar 2003
Olympia, WA.
Where are the instructions for the install???
Rebuilt bird
Apr 2003
Royersford, PA
check out www.pa-performance.com. He offers the 3g upgrade kit with the wiring and diagrams. His name is Rick and he will hook you up. His diagrams are really nice.
