Gary F
Jan 2004
Lakewood, California USA
Found one that looks new at the JY from a '94 Sable. There's a small plug with a white/black small-gauge wire coming from it. I searched the site but it was never mentioned. What does it connect to? Anyone know?
Gary Fraser
I used to be normal...then I got a Turbo Coupe.
'88 T5 Bone Stock w/3G Alt.
Rod K
Dec 2003
Charlotte, NC, US
It connects to the black/white wire in the D plug on your existing alternator.
There is a good write up on installing a 3g in the tech articles section.
Rod Kiser, '88TC, 5 speed, 5 lug, Cobra 13" front brakes, Mark VII 11 1/4" rear disc brakes, PiMP'n, Bullit wheels, ATR 3" exhaust, Aluminum driveshaft, EDIS, 60 LB injectors, gutted upper & ported lower. NATO Member
Gary F
Jan 2004
Thanks
Gary Fraser
RDOG
Ontario. California U.S.A.
Go and get the nice thick alt gauge wire of a 94 stang or 92 SC Tbird. It will also have a 175amp fuse too.
Gary F
Jan 2004
Good idea. Shoot. I walked right past an SC on my way to the Sable.
Gary Fraser
Liquid_force
Lawrence, KS USA
FWIW - with a minor "massage" of the TC alt bracket the SC alt will bolt and plug right in for 110A.
I ran a supplemental 8 ga from alt output stud to batt (+) and proceeded to run a ridiculously powerful soundsystem for about 3 yrs with an old cheap wal-mart battery and never had an issue.
88 TC -- Dark Blue 283k
RIP - 9/22/07
She was a great TC and went down swinging ![Smile Smile](https://turbotbird.com/images/smilies/smile.png)
Now -- Me: A minivan, I'll spare you the details.
Her: '09 VW Tiguan AWD 2.0T 101k
Gary F
Jan 2004
I know. I did all that once. I'm replacing the 110A with the 130A. In fact, I finished the job Sunday. Works great. As for the plug, I pulled the red insert out and the rubber stopper from the plug also. I used a tiny screwdriver and inserted it in the plug next to the A connecter and the S connector and was able to switch them without having to do any splicing. They pull right out and snap right back in again.
Gary Fraser
