30lb of boost
bckslyr2003 Offline
i have an stock 83 thunderbird turbo coupe i have up'ed the boost to 20-30psi what harmful effects can this have on my motor i would apriciate any information ne1 has thankyou
deadbird Offline
i would say the head gaskets for one. The head. alot. you might want to get a fuel pump to keep up with that too.
1987 5 sp.
- 4.6 2v swap.
Which is it, 20? or 30?. How's it run?
There is a HUGE difference between 20 and 30 psi. 20 is within the turbos higher efficiency range, but 30 is WAY outside the efficiency range.
Are you running an intercooler? Anything above the low -mid teens you should run one.
I can almost guarantee that the stock fuel pump will not be able to keep up at 30 psi, and mayne not even at 20.
88 Turbo Coupe: Intake and exhaust mods, T3 turbo at 21 psi, forced air intercooler, water injection, bypass valve, Ranger roller cam, subframes, etc., etc.. // 86 Tbird 5.0 (original owner): intake, exhaust, valvetrain mods, 100 HP nitrous, ignition, gears, suspension, etc., etc.... // 91 Escort: Bone stock winter car // 02 Taurus Vulcan(wifes car)
bckslyr2003 Offline
I HAVE BLOCKED OFF MY BOV WITH A PLAT WHEN MY CAR IS AT IDLE IT RUNS 20LB OF BOOST WHEN I REVIT IT UP THE GAUGE GOES TO 30LB OF BOOST MT TURBO IS ALWAS SPOOLING SINCE I PUT THT BLOCK OFF PLATE ON TY
natmac3 Offline
Do you mean that you blocked off your Wastegate? Plugging a BOV will not change anything until you shift under boost.
20psi at idle is some Extreme cylinder pressure!!!
May your engine rest in peace...
--n8
1987tc
bckslyr2003 Offline
and is there any way to figure ou how many horsepower will be gained with tht much boost ?
bckslyr2003 Offline
natmac3 i blocked off my wastegate so what your sayin is my engine is going to go boom lol i was reading sometin about cr it said somtin if i have to high of boost my motor will get rally hot and detonate
Nsw Offline
my question is what couldent go wrong making that much boost? your gonna run that thing soooo lean, blow your head gasket, detonate like crazy and probbaly burn that turbo out pritty fast.
1988 5speed black every option. 3inch single turbo to tail(stinger), manual boost control. k&n cone walbro fuel pump
1986 xr4ti project car..... way to many mods to list.
bckslyr2003 Offline
ok how would i make it run richer i know i need to get more fuel pressure but what else could i do to slow its destruction ?
