Blade1433
Columbus, Ohio, USA
If I could get an 86-93 Mustang fuel pump cheap enough, would it fit?
Thanks, James
Blade
"Drive it like you stole it"
88 bone stock TC with 138k, 5spd, burgundy, almost all options. Soon to have a pillar boost guage along with new tires, zinc plated rotors and a custom paint job
SteveX82
Toms River, New Jersey
This is the pump a few of us on the board(including me) are running:
http://www.jdsperformance.com/index.asp?...&fcmd=item
It'll certainly fit. Very minor trimming (easy enough to do with a handsaw or a good pair of shears) of the stock rubber isolator sleeve is required if you want to use the new filter, or you can just buy the "correct" filter from Ford. You'll also need a new pump-bracket to tank O-ring because the one supplied in the kit is too small (about 2" diameter for the mustang). Other than that, the installation is a peice of cake. Just make sure you have as little gas in the tank as possible before dropping it. Dropping the tank is one thing, but getting it back up there and lined up by yourself is a hell of a backache. I'd also suggest buying the kirban adjustable fpr at the same page while you're at it. It does wonders for smoothing up acceleration and allowing a bit of tinkering at different boost settings. Here's the link for that, too:
Good luck
maroon 1987 TC 5spd, 125k miles
k&n mounted in front of radiator with 3" pvc piping, gillis valve set at 17lbs, kirban adjustable fpr set at ?, walbro 255 hi-pressure pump, crappyass rear tires
Best 1/4 mile: 14.857
Best trap speed: 94.01mph
[This message has been edited by SteveX82 (edited 11-10-2001).]
Estoril blue 1987 TC 5spd, 148k mi, a237, Bailey BOV, spec stg3 clutch, spearco FMIC, 50 trim t3/t4, 3" exhaust, Bamafuel, LM1, 55pph
Best 1/4 mile: 12.31 @ 110mph on 25psi
