#11 |
Quote:Originally posted by Harvs:
Cool, so what are your thoughts for the motor?
How about this(link) with one of the above turbos, a F.A.S.T. stand alone and some big injectors.
http://www.turboford.org/ubb/ultimatebb....6;t=005491
Don't forget that the 255lph pump and stock fuel rails won't support that power. Now you are looking at sumping the stock tank or fuel cell, new fuel lines, big fuel pump, new adj. regulator that accepts the new lines. Look at around $1000 for the fuel system. That is probably a conservative guess on the cost also.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), .500 lift roller cam, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Star stage III clutch, Greddy Profec B boost controller, Weld Draglites with M/T ET Street 26x11.5/15
[This message has been edited by Glenn 88TC (edited 02-17-2004).]
NO TC and NO headaches.
