Import Killer
Lincoln, DE USA
So i just get done going through almost a whole tank and got around 200 miles to the tank. I dont get too hard on my car, and i do a lot of highway driving. Does this sound like my car is running very rich?
Soon, im replacing the TFI and PIP with motorcraft parts, thats where im starting. I changed the pressure regulator and have a new O2 sensor.
I have motorcraft wires, autolite plugs, clean air filter, 3in exhaust, no EGR, anything else to replace?
1987 Turbocoupe
Painted sonic blue pearl
Ground effects w/S351 wing
17x9 Chrome Cobra Rs
255/45/ZR17 Kumho 712s
KYB suspension
MOMO shift knob and boot
K&N cone air filter, Gillis boost valve, T-3 turbo, ported intake and E6, A237 roller cam, MSD coil, Kirban FPR
Full 3" exhuast w/Ultra Flo muffler
Brute force clutch
White faced indiglo gauges
2 12" Rockford Fosgate subs and amp
THUNDERPINTO
Nov 2004
KENT ,NY, USA
you bet. i get well over 300 to a tank.
2 87 TC's one is a Watkins Glen
88 TC no engine or interior,a no rust project
66 mustang coupe,71 triumph spit
52 Dodge powerwagon(s)
79 TC powered Pinto
99 Harley Roadking
73 750 Norton Commando Combat
Ryan H
Panama City, FL
You can expect a bit of a drop with the mods you have, but even 20 on the highway is a bit low. Not having the EGR can make you lose a few MPG.
What diagnostics have you done?
Import Killer
Lincoln, DE USA
Well after i put in my new fuel pump, TFI, and PIP, im gonna go over the whole fuel diagnostic and pull codes again. I'll let you guys know what happens
1987 Turbocoupe
KYB suspension
Brute force clutch
Sounds like about what Im getting, filled up last Thursday, had to put gas in today, had 173 on the odom
1988 Turbo Coupe - A237 cam, K&N Cone, T3(.60-.63), 255 Walbro, Gillis BV, gutted and knifed intakes, ported e6, 3" elbow/dp to dual 2.5s, Kirban and spearco fmic.
Up next, ported head, t3/t4 upgrade.
Ryan H
Panama City, FL
Not to make you sound stupid but how exactly are you calculating your gas mileage? If you are using the gas gauge, you could very well be wrong.
My gas gauge goes on empty and I can usually get another 130 miles before it actually runs out of fuel. I calculate my mileage by topping off my tank and using my trip meter, then topping off again and going by gas put in the tank vs. mileage on the trip. I get around 350 miles to 17 gallons. If I top off, I can get about 400 per tank.
trashline
Feb 2005
Levittown, PA
I get about 18-19 mpg but most of my driving is around town and racing to the firehouse twice a day. 15 seems low from your stand point. I usually fill up and reset the trip odometer run it till it is empty when i fill it up i divide the # of gallons into the # of miles. So if i fill up and put 20 gallons in and I drive 350 miles I do 350/20 which = 17.5 mpg. If you do this over a couple weeks you may get numbers like 17.5,19,18.8,16. so add them all up and divide by the number of times you calculated the mpg. so above it is 4 times, so they = 68.3 that divided by 4 is 17.075. which is your average mpg for 4 fill ups.
Liquid_force
Lawrence, KS USA
my mileage got that bad twice.
once was a bad FPR
once was a cracked fuel line
88 TC -- Dark Blue 283k
RIP - 9/22/07
She was a great TC and went down swinging
Now -- Me: A minivan, I'll spare you the details.
Her: '09 VW Tiguan AWD 2.0T 101k
Import Killer
Lincoln, DE USA
Well im going to drive a little easier on this tank, and do an actual calculation next time i fill up. I might get 18 or 20 at best, but when i first got the car, with the original motor, i swore i got like 25, with 180,000 miles.
1987 Turbocoupe
KYB suspension
Brute force clutch
