1/8 th Mile ET
guitrplyr Offline
Howdy folks. Semi newb TC owner here. 1 month. Just got mine tuned up and running smooth. I have a stock 88TC 5 speed. I am about to add a cold air K&N setup (per the tech section) a gillis valve, and a 3" exhaust system. Thats prolly all I'll do until I need a rebuild. My question is this. I'm stuck here in sweet home alabamy and all we have even semi close are 8th mile tracks. I searched the board but never found any 8th mile ETs. I even posted on another site for ideas and got all kinds of math formulas but no "real" times. Any help would be most appreciated.
88 TC 5 Speed Stock.
"I miss my Ex.....but my aim is getting better"
87 TC 5 Speed Stock K&N.
dixiedude06 Offline
1/4 mile et is approximately 1.55 times the 1/8 mile et. 1/4 mile speed is approximately 1.24 times the 1/8 mile speed. According to turbofords equation page
87 turbocoupe, 5-speed, Completely loaded, superchip, bleeder valve set to 17 psi, Kn cone
87 turbocoupe, 5-speed, Completely loaded, some mods
93 F-150 Lightning #4593 of 5276
13.9 @ 99 mph
When my car (w/ the old engine) went 15.144 @ 91.46 in the 1/4, the timeslip says 9.73 sec @72.98 for the 1/8. This was on a K&N, 3"dp into dual 2.5" and a boost valve.
You might want to look through the Drag Time Slip forum. There are some 1/8 times in there
NATO Member
88 TC X 2, 86 SVO, Main TC with K&N, 3"DP to 2.5"duals through Dynamax, Ric valve at 17+ and disconnected KS. Elite Bodega 16" chrome wheels. Autometer pod w/ A/F and Vac/boost gauges.140 mph Motorsports Speedo New engine: Total Seal rings and TRW pistons, ported and polished head w/ cc'd chambers,1.59"exhausts, SS valves, gutted upper, knife edged lower, A-230 cam, Race Engineering Adj Cam Sprocket, Crowlers, ARP head studs, and rod bolts. Walbro 255 HP pump and Kirban adj FPR, T-3. Centerforce II, KB subs and jack rails.
Dan E Offline
In general, you should probably be seeing mid to high 10 sec+ 1/8 mile ET's without any mods and low to mid 9 sec ET's with mods.
Yeah, there are only 1/8 mile tracks around here too which really sucks...since our TC's do much better in the second half of a 1/4 mile !
We have a whole section on Drag Slip Times...there are several times in there to check.
My best times so far (pump gas):
R/T .567
60' 2.276
1/8 ET 9.493
1/8 MPH 77.01
1/4 ET 14.597
1/4 MPH 95.46
Dan Eaves
88TC 5spd, Crower 5.5" Sportsman Rods, Short Wiseco Pistons bored .030" Over, Ported Head with Polished Combustion Chambers, Gutted & Polished Upper, Ported & Polished Lower, Polished T/B, Ported E6, SVO T3 .63AR Turbo, Bosch Bypass Valve, 3" DP w/No Cat, 2 1/2" DynoMax single cat back w/DynoMax Super Turbo Muffler, RR Cam, K&N in Fenderwell, Gillis Boost Valve, Centerforce I Clutch, Removed A/C, Polished Wheels, Polished Valve Cover, Polished Crank and W/P Pulleys, Walbro 255LPH HP Pump, Kirban Adj FPR, and the DAMN Heater Core is new too !
NATO MEMBER (Vice Chairman...if it's a vice...I deal with it)
Dan Eaves
guitrplyr Offline
Thanks for the info guys,...Dan, Killer TC hope mine turns out half as sharp. How the hell did ya get those rims that polished?
Glenn 88TC Offline
Here is my best run to date.
60' - 1.802
330' - 5.619
1/8 - 8.781
1/8 mph - 78.21
1000' - 11.511
1/4 - 13.809
mph - 98.48
Hopefully I will shatter these numbers later this year.
Glenn 88TC
current mods (13.809 at 98.48mph): ported & polished big valve head(1.89/1.59), ranger roller, gutted upper and ported lower intakes, t3/t4 turbo, MSD 6al, MSD Launch Control, K&N filter, Walboro 255 pump, Kirban adj. fuel reg., ATR header, full 3" exhaust with Dynomax Ultraflow muffler, Star stage III ceramic clutch, Tiny Avenger bleed valve, Weld Draglites with M/T ET Street 26x11.5/15
Winter 2001-2002 upgrades - powerstroke intercooler(mounted full size or it won't be going in), 65mm throttle body, 42lb. injectors, custom grind roller cam, big turbo, rear suspension upgrades
NO TC and NO headaches.
SteveX82 Offline
That was a good point you brought up, guitrplyr. I guess I take the local 1/4 mile tracks for granted and forget that others may be stuck with only 1/8th mile ones. But anyways, here's the quickest of my most recent timeslips:
R/T : .553
60' : 2.198
330 : 6.184
1/8 : 9.492
mph : 74.41
1000: 12.278
1/4 : 14.778
mph : 93.38
maroon 1987 TC 5spd, 128k miles
k&n cone in fenderwell, gillis valve set at 17lbs, kirban adjustable fpr set at 40psi, walbro 255 hi-pressure pump, bosch hi-pressure bypass valve, ported e6
Best 1/4 mile: 14.778 (with 2.198 60' time)
Best trap speed: 94.01mph
Estoril blue 1987 TC 5spd, 148k mi, a237, Bailey BOV, spec stg3 clutch, spearco FMIC, 50 trim t3/t4, 3" exhaust, Bamafuel, LM1, 55pph
Best 1/4 mile: 12.31 @ 110mph on 25psi
Dan E Offline
Steve:
Are you running an IHI still ? The reason I ask is that our 1/8 Mile ET's are practically identical, but I gained almost 2/10th's on your 1/4 ET...just wondering if it's due to a T3 vs IHI ?
Of course, there is one thing I have found out aboout ET's and Trap Speeds...there are like 400,000 variables from track temp and condition, shifting, to you name it that change the outcome of things. I have had slower ET's and faster trap speeds and visa versa...
Dan Eaves
SteveX82 Offline
Yep, I've still got the ihi on there (for now at least....a .48 t3 and a few other things are going on in 2 weeks). The car feels really strong for the few 1/8th mile, but once it's strung out in 3rd gear, the ihi just feels like it can't flow enough air to keep up the power.
Of course, your trap speed at the 1/8th mile was almost 3mph faster, but by the 1/4 mile it was "only" 2mph faster. As you said, there are a myriad of factors that contribute to the actual e.t. of the car, so i'm sure they explain away most of the differences. How much boost were you running?
