rairbird
Feb 2003
Toronto, Ontario, Canada
Is the BP sensor the MAP sensor. I have a flashing CEL. After checking the codes I get 22, BP sensor out of test range, as referenced in the Tech. Art. section. Then I got a flashing Climate Control panel, and then, an Antilock brake light. All I need now is for the Ride Control light to start blinking. Anyone for pinball?
Joe F
Jul 2002
Hawkins, Texas - USA
Our BP (Barometric Pressure) sensor is kind of equivilent to a MAP (Manifold Absolute Pressure) sensor. Our TC's only measure atmospheric pressure to provide the EEC with altitude information. It's only got wires hooked to it, and *does not* connect to anything with a vacuum hose.
HTH.
Joe F.
My 87 TC & mod list with sources
rairbird
Feb 2003
Thanks JoeCool. I guess I meant to ask if its the sensor that's on the firewall, like the MAP on other cars. I guess it is.
Joe F
Jul 2002
In an 87 (the only year I can vouch for) its mounter on the passenger wheelwell on a bracket the also mounts the IRCM.
HTH.
P.S. It looks pretty much like a MAP sensor, too.
[This message has been edited by JoeCool (edited 04-06-2004).]
Glenn 88TC
Lebanon, PA
HTH.
My 88 is in the same place.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), .500 lift roller cam, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Star stage III clutch, Greddy Profec B boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
rairbird
Feb 2003
I think I understand. Its the small piece that sits right on top of the IRCM that has a small breather hole, right?
Joe F
Jul 2002
This is my BAP (not stock mounting).
rairbird
Feb 2003
Thanks again JoeCool, and Glenn. I found the problem. The sensor got disconnected while I was screwing around and reflaring the turbo oil line. All is O.K. now.
Joe F
Jul 2002
Great! Glad to have been of help.
