#1 |
I'm getting ready to pull the motor out of my 88TC. I also have another motor on a stand that's almost completely torn down. Here are the current states of these motors:
Spare Motor:
- believe it came from an 84 with 80ish-k miles on it
- No known issues from previous owner
- Motor looks to be in good shape. Cylinders look good with original crosshatching still visible
Motor coming out of the car:
- 95k miles
- Was smoking a little; I believe this was from bad valve stem seals. Ran strong otherwise
Just to give an idea on plans for the car: it is getting completely torn down with everything getting looked at and upgraded. Interior has been removed along all wiring on the car. Wiring will be replaced with a new Ron Francis engine harness, painless performance chassis harness, and the current Pimp ECU. T5 transmission is getting replaced for a TKX with v8 clutch conversion. Car is getting a tubular k member to compliment the current coilover setup. Ideally, I'd like to eventually road race/time attack the car. There will be more on this as I plan to document everything here once the rebuild of the car starts. Stay tuned for that.
As for the motors, my plan is to refresh one and have the other built with aftermarket rods and pistons. For the refresh, I'm thinking rod and main bearings, piston rings, and all associated gaskets. The motor will be receiving a boport stage 3 head with 2.1 cam, boport tubular exhaust manifold and garret t3/t4 turbo. What's everyone thoughts on the approach for the refresh? Should I go with all new bearings, rings, gaskets, etc. or would I be better off with just checking the rod bearings and replacing them with all associated gaskets? Thanks!
Spare Motor:
- 95k miles
88 Turbo Coupe: Front mount intercooler, MGW short throw shifter, full coilover conversion, tubular control arms front and rear, svo front brakes, vacuum assist brake swap, manual steering swap, GT35R turbo with external gate, pimpx ecu, 60lb injectors, 3 core aluminum radiator, Boport 1.5 cam, gutted upper, corbeau fixed back seats, and the list goes on.
