rich
Dec 2002
tampa, FL USA
Hi guys,
1. If I use a gillis valve, do I need to keep my bcs connected electrically for the ecu?
2. Is there a difference between the Map Sensor (with vacuum disconnected)in the N/A vs the BPS in the tbird? I have both available.
Thanks
Dan E
Greensboro, NC
If you use a Gillis you don't have to have the BCS plugged in for the EEC. However, if you unplug it you will throw a code on your scanner at KOEO.
Dan Eaves
88TC 5spd, Crower 5.5" Sportsman Rods, Short Wiseco Pistons bored .030" Over, Ported Head with Polished Combustion Chambers, Gutted & Polished Upper, Ported & Polished Lower, Polished T/B, Ported E6, SVO T3 .63AR Turbo, Bosch Bypass Valve, 3" DP w/No Cat, 2 1/2" DynoMax single cat back w/DynoMax Super Turbo Muffler, RR Cam, K&N in Fenderwell, Gillis Boost Valve, Centerforce I Clutch, Removed A/C, Polished Wheels, Polished Valve Cover, Polished Crank and W/P Pulleys, Walbro 255LPH HP Pump, Kirban Adj FPR, and the DAMN Heater Core is new too !
http://www.geocities.com/wot_turbo/WOT.html
NATO MEMBER (Vice Chairman...if it's a vice...I deal with it)
[This message has been edited by Dan E (edited 12-16-2002).]
Dan Eaves
Quote:Originally posted by rich:
Hi guys,
You can remove the BCS entirely with no ill efects. You will get a code 81 during the KOEO test if it is removed, which you can just ignore, or, if you dont want to see the code 81, put a 100 ohm, 1 Watt resistor across the BCS electrical connector.
Sent yo an E mail on that one.
Thanks
rich
Dec 2002
tampa, FL USA
