Robert Camp
Jan 2006
Raleigh, NC
Each axle should have had a tag held on by one of the differential cap bolts. Can you document the tag numbers with each axle you describe?
Robert Camp
'86 Medium Regatta Blue TC, 5-speed, original owner.
TurboCoupe50
Chesapeake, Va
We've been there, done that, check out the sticky's...
http://www.foxtbirdcougarforums.com/foru...train-Tech
RDOG
Ontario. California U.S.A.
Read the chart, BUT what may have been left out is the fact of when your car was built IF its an 86. It may have a 85 rear depending on how early the car was built making the 86 a oddball year that may have different length rear ends depending on build date.
Chart in question...
http://i158.photobucket.com/albums/t97/b...apcopy.jpg
Robert Camp
Jan 2006
Raleigh, NC
I'm not asking for a decode, I can do that. I wanted to know what the tags were on his axles.
Robert Camp
TurboCoupe50
Chesapeake, Va
[b] We've been there, done that, check out the sticky's...
http://i158.photobucket.com/albums/t97/b...apcopy.jpg [/b]
True, the early '86 did use the same rear housings as the '85...
