Struts / Shocks - Too good 2 B True?
Mark'87TC Offline
#11
also, i have no qualms getting rid of PRC. call me old fashioned, im not a fan of ABS either
cammed99 Offline
#12
I got some rear shocks for my 88 from advance for $13 [Image: biggrin.gif]
89 TTA (yes the turbo one)
65 Mustang Fastback 2+2
98 GT
99 Ram 2500 4x4 Cummins on 35's
82 Bronco 4x4 FOR SALE
Resurectedbird Offline
#13
I have the Sensatrac strut/shock setup on mine with the Koni lowering springs. It handles really well and I like them. The only reason why I went with this is cause my suspension was totally whooped with 206,000 and never touched. I would recommend monroe stuff if you can't get anything else.
Currently birdless, but will get another someday!
Turbobob_dup1 Offline
#14
I had bolted right up a set of Gabriels on the front of my coupe that came off an 81 Capri 5.0. The rears wouldn't fit of course but as mentioned they're fine anyway.
The fronts did have to be shimed to fit but was no big deal. They'r not too short either if your woundering.
BUT all this will change this winter 'cause I just baught a parts car and the PRC works , so I'll be going back to stock. [Image: smile.gif]
87 Turbocoupe,T3/T4 turbo,much porting,AFPR,255lph pump,GN cooler,K&N in the fender,gutted upper/knife edge lower,big valve head,roller cam,60mm throttle body,Talon 1G BPV.
www.geocities.com/turbobob23/photopageThunderbird.html
87 Turbocoupe,T3/T4 turbo,much porting,AFPR,255lph pump,GN cooler,K&N in fender,gutted upper/knifed lower,big valve head,A237 cam ,60mm throttle body,Talon 1G BPV.
4 + 1 = 8!!
ThunderChickenTC Offline
#15
hey bro, that sucks, i would try other autozones, because the one i tried was on field ertel rd., located in deerfield township.....located in ohio. they said they had some in stock in the warehouse, so they had went and pulled me the set since i was willing to buy them. I went to autozone to fix my thunderchicken yesterday, and i should have asked them, but forgot to ask... i will go back and see if they have anymore in the warehouse, i'll be in touch.
Dennis, a.k.a. Thunder Chicken
88 TC ....Custom window tint, American Racing 15" rims with Michelin X-radial tires 215-70-r15, 9mm Ford Racing Spark-plug wires, K&N air filter, 3 core radiator, 180* Thermostat, Head completely rebuilt with an upgrade to a roller-cam, Silvannia Silverstar Bulbs for headlights, Painted wiper blades, XM Radio, Custom system with a custom built 5 cu. ft. box(2 and 1/2 cu. ft. per sub.), Custom Alarm System. Next is Magnaflow exhaust mod!!!
JLockhart Offline
#16
Dennis, let us know, thanks.
[This message has been edited by JLockhart (edited 12-11-2003).]
87 TC, T5, t3/t4, alky spray, 3" exhaust. 13.65 @ 102.75 on radials
#17
Does anyone know if the Super Coupe struts could be adapted to the TC? I know they were manufactured by Tokico. Probably could not be used on a TC since it's a completely different vehicle....
That is a good question. There are some people on this board that own both an 87-88 TC and an SC..... maybe one of those people will be able to compare a TC and SC strut side by side, and see if the SC strut could be some how adapted to the TC.
88 Turbo Coupe: Intake and exhaust mods, T3 turbo at 20 psi, forced air intercooler, water injection, bypass valve, Ranger roller cam, subframes, etc., etc.. // 86 Tbird 5.0 (original owner): intake, exhaust, valvetrain mods, 100 HP nitrous, ignition, gears, suspension, etc., etc.... // 91 Escort: Bone stock winter car // 02 Taurus Vulcan(wifes car)
