BJL
Williamstown, New Jersey
I have been using the Ford Racing 9mm universal 4 cylinder wires, well first its s pain in the ass to cut the to length and get the boots on the wires, second those things break off when i need to check or change the plugs, and third, they work great until I break them, grr, i have a set of original ford wires with the 1988 date on em, they work fine, lol *knock on wood*
Brian Larkin
88TC 330,000 miles
Slightly Modified
Wags88TC
Las Vegas
I was thinking about buying V-8 wires and having "2" sets, but not sure if the "short" wires will make it over the rocker cover!
Steve Wagner
Nato member
84 SVO
88TC, 5 speed, StageII Star clutch w/ StageIII pressure plate,lightened flywheel, K&N in fender, gillis valve, 255lph Walbro, Kirban adj.FPR,Bypass valve, 3" exhaust (high flow cat/ Magnaflow muffler), A-pillar gauges(A/F & Boost), 16" ARE 5 spoke wheels 7" front 8" rear(225/50VR16 / 245/50VR16 Yokos'). Subframe connectors
