Hi, folks. I'm getting ready to do quite a bit of welding in the interior of the Bird. I want to remove the headliner before I do. However, I'd like a consult before I try to remove the map lights/overhead console. The shop manual says to put a small screwdriver in the slot at the rear of the map light and pull down the edge. Problem is that the only slot I see is at the front of the light. If you look at the photo, you can see a small recess at the front of the light bezel that I assume is for prying. I don't want to break the thing. If anyone has pointers, I'd appreciate it.
1931 Deluxe Coupe
1949 Club Coupe
1951 F-1
1971 Torino GT Convertible
1988 Thunderbird Turbocoupe
1949 Club Coupe
1951 F-1
