Coupedaddy
Sep 2002
Chicago, Il
The door lock switch / button (in the door panel) appears to have failed and is apparently stuck and drawing down my battery. I want to pull it and check it out or replace it but I don't see a way to get it out without taking off the whole door panel. It doesn't look like something I can just pry out with a screwdriver and I don't want to damage the panel. Is there a trick to getting it out or do I have to take the panel off?
Cupddy
06-09-2022, 01:37 PM
(This post was last modified: 06-09-2022, 05:39 PM by 88turbomajor.)
(06-08-2022, 01:05 AM)Coupedaddy Wrote: The door lock switch / button (in the door panel) appears to have failed and is apparently stuck and drawing down my battery. I want to pull it and check it out or replace it but I don't see a way to get it out without taking off the whole door panel. It doesn't look like something I can just pry out with a screwdriver and I don't want to damage the panel. Is there a trick to getting it out or do I have to take the panel off?
From what I remember, that switch just pops out. Gently pry the top up using a dull butter knife. But, if you don't want to do that, as Brad has stated, the arm rest is easy to remove and you'll have access to the door lock switch set.
1984 Mercury Cougar 5.0L LS Silver/Gray (New 5.0L with E7 heads and HO cam)
Previous: 1988 Turbo Coupe
BradM
Dec 2020
Barrington, Illinois
You can take the arm rest/door pull off without removing the entire door panel. The arm rest pops straight up and out and will expose the screws for the rest of the door pull. Pretty easy.
Coupedaddy
Sep 2002
Chicago, Il
Pried up nice and easy, popped right out! Thanks. And as expected, the switch is fried. Now I'm looking for a replacement.
Cupddy
