UncleJohnsBird
May 2022
Northern Wisconsin
I’m removing the blower motor to clean out an apparent mouse nest. I removed the 3 screws and pulled the blower rearward as far as I could but still can’t clear. Any tricks are appreciated!
88Slowbird
May 2019
Tampa, FL
(05-22-2022, 06:15 PM)UncleJohnsBird Wrote: I’m removing the blower motor to clean out an apparent mouse nest. I removed the 3 screws and pulled the blower rearward as far as I could but still can’t clear. Any tricks are appreciated!
do you have manual or electronic A/C controls? with the manual you can pull the blower box out easy but with the electronic you'll need to pull the dash to get it out
UncleJohnsBird
May 2022
Northern Wisconsin
05-23-2022, 04:22 PM
(05-23-2022, 03:21 PM)88Slowbird Wrote: (05-22-2022, 06:15 PM)UncleJohnsBird Wrote: I’m removing the blower motor to clean out an apparent mouse nest. I removed the 3 screws and pulled the blower rearward as far as I could but still can’t clear. Any tricks are appreciated!
I have the electronic controls. Grrr.
gtbird
Dec 2001
Hope, RI 02831
Check this out for information on removal of dash:
https://www.coolcats.net/repairing/#heating
Lots of great info on this site, Cougars and Tbirds are very similar if not the same in most areas.
Be extremely careful removing speaker grills, do not try to pry them out around the edges or you’ll crack the brittle dash. Form a hook out of a piece of stiff wire and fish it down through one of the slots and pull up.
Good luck and have a little patience while performing this task.
While you’re involved in this, it would be wise to replace your heater core at this time. Get a Motorcraft part, not a cheap auto parts store brand.
05-24-2022, 11:42 AM
(This post was last modified: 05-24-2022, 11:43 AM by spittinfire.)
(05-23-2022, 04:22 PM)UncleJohnsBird Wrote: (05-23-2022, 03:21 PM)88Slowbird Wrote: (05-22-2022, 06:15 PM)UncleJohnsBird Wrote: I’m removing the blower motor to clean out an apparent mouse nest. I removed the 3 screws and pulled the blower rearward as far as I could but still can’t clear. Any tricks are appreciated!
You do not have to take the dash out, at least I didn't. I have an 88 with electronic controls and I simply took out the screws and wiggled it around until it came out. I remember having to play with it some but it did come out and it went right back in the same way. I had a mouse in mine apparently too and the wheel was so full I was amazed it moved any air at all.
