my aunt told me it overheated it was her car. the car is in Michigan and I'm getting it towed here to Florida. she was the only owner, I believe she got it in 1990.
I'm wondering if it could possibly be the reducer for the heater core that's making it overheat?
You could do a couple of simple cooling system things just has drain it, flush the radiator out with a garden hose, pull a heater hose and flush the heater core with the hose, put a new thermostat in it. It could be a number of things. If it were me, I would get it home and just try to get it running. Once it's running you can start trying to diagnose problems.
(04-18-2022, 12:26 PM)spittinfire Wrote: You could do a couple of simple cooling system things just has drain it, flush the radiator out with a garden hose, pull a heater hose and flush the heater core with the hose, put a new thermostat in it. It could be a number of things. If it were me, I would get it home and just try to get it running. Once it's running you can start trying to diagnose problems. ok thanks
88Slowbird
May 2019
Tampa, FL
where in FL are you? I'm down in tampa with a few birds
