BabyBlueBird
Jun 2021
Havre De Grace Maryland
I have been going through and replacing gaskets on my TC and found that the original PCV and hoses are starting to go. I’ve read stingers forum on there Catch can set up to replace the PCV. Not sure if it’s worth it on a pretty much stock car. Does anyone know if motor craft part # EV-98-B is the pcv I need?
88Slowbird
May 2019
Tampa, FL
04-18-2022, 07:25 PM
(This post was last modified: 04-18-2022, 07:26 PM by 88Slowbird.
Edit Reason: text messed up
I read to use EV-127-A so that's what I run in mine
EV127A is the correct part.
My Tbird 5.0 uses the EV98B.
