Boost leak?.
Adrock Offline
So why am I hearing my boost venting to atmosphere? It sounds like I have a blow off valve with two light of a spring or one that is stuck open. But as I understand my car with the ihi baby turbo doesn't even have a blow off valve correct? So where is it coming from why do I hear it so loud and why is it happening?
BigJake Offline
Check your intercooler turbo, throttle body hoses for damage or blown off.
1987 Thunderbird Turbo Coupe 5 speed Boosting 25 PSI with Boport/Stinger parts !
Jeff K and Adrock like this post
Mikey97D Offline
The coupling between the intercooler and turbo went bad on mine probably because of all the heat coming off the turbo. I replaced the coupling to fix because the original was in very bad shape.
Within a year or so of getting my TC the turbo to stock IC blew at 15 psi boost. It split nearly in half and made a HUGE bang. Got some replacement silicone hoses and T bolt clamps that have have held up fine at 24 psi boost for the last 21 years.
Adrock Offline
That was it. Thanks guys
Mikey97D likes this post
