So I just bought an 87 turbo coupe cherry great condition in molested. So I went to put in a wide band AFR today and I just put it in the location of the factory O2 sensor..I hooked it up to the plug right there. Power to grey and yellow wire, ground to blk grn and sensor to ppl grn.. then all of a sudden I get in the car and it's running horrible it gets it right when it hits boost it starts like bucking and missing and interesting enough the gauge says that the fuel mixture is right on and I wouldn't think that the O2 sensor has enough authority to cause the engine to run that poorly... Is this just a coincidence that something else is happening at this moment? Did I possibly bump something in that area? With the fuel being good and it's happening right when it gets up in the boost it makes me think ignition hey check the plugs they're all gapped right at 30 so I don't think they're blowing out I checked the timing its set at base timing at 10°...I am not familiar with the component that is in the place of the mass air sensor..could this be causing my issues? Oh I am also recently bumped up the boost to 18-19 psi....it was running great for a few days.....thank you in advance
88Slowbird
May 2019
Tampa, FL
(02-08-2022, 12:15 PM)Adrock Wrote: So I just bought an 87 turbo coupe cherry great condition in molested. So I went to put in a wide band AFR today and I just put it in the location of the factory O2 sensor..I hooked it up to the plug right there. Power to grey and yellow wire, ground to blk grn and sensor to ppl grn.. then all of a sudden I get in the car and it's running horrible it gets it right when it hits boost it starts like bucking and missing and interesting enough the gauge says that the fuel mixture is right on and I wouldn't think that the O2 sensor has enough authority to cause the engine to run that poorly... Is this just a coincidence that something else is happening at this moment? Did I possibly bump something in that area? With the fuel being good and it's happening right when it gets up in the boost it makes me think ignition hey check the plugs they're all gapped right at 30 so I don't think they're blowing out I checked the timing its set at base timing at 10°...I am not familiar with the component that is in the place of the mass air sensor..could this be causing my issues? Oh I am also recently bumped up the boost to 18-19 psi....it was running great for a few days.....thank you in advance
you have to keep the factory O2 installed it needs that to run on the stock ECU
you'll need the put the wideband somewhere else on the exhaust
1985 SVO: Pro 5.0 Shifter, Boport valve springs, Manual boost controller, AEM wideband
1985 TC 5 Speed
BradM
Dec 2020
Barrington, Illinois
OEM O2 sensor is narrowband. You cannot replace it with a WB and use the OEM ECU.
(02-08-2022, 06:29 PM)BradM Wrote: OEM O2 sensor is narrowband. You cannot replace it with a WB and use the OEM ECU.
I understand that but most wide bands have a setting or a wire that is uses the zero to one volt reference just for the narrow band signal that the ECU is looking for in my AEM wideband part number 30-4110 if you turn the setting to p04 then the white wire that normally sends the 0 to 5 volt reference for the wideband in this case sends a 0 to 1 volt reference to the ECU which is the narrow band signal. Regardless even if it were that that's incorrect would the O2 sensor alone be enough to cause the vehicle to run like this? I wouldn't think so
Another thing I just noticed is that when the car does start cutting out another thing that happens in unison with the cutting out is the tachometer spikes like the needle flies up into the red zone which obviously isn't what's happening but it tells me that the problem is most likely with the ignition system?
teal95
Dec 2002
Grass Lake, MI
Remove the WB and put the NB sensor back in. Then troubleshoot. One change at a time.
steve
'83 & '84 GT turbo EEC-Tuner
'85.5 & '86 SVO twEECer
2x '87 & '88 TC QuarterHorse
'93 LX 5.0 notch Moates chips
3x '95 & '96 GT
Kuch
Sep 2016
Manlius, NY USA
agreed, you have to put the narrowband back in the stock location to run correctly with a factory ECU. If you want to use the wideband install a bung in the downpipe about 24" from the turbo.
88Slowbird likes this post
(02-09-2022, 01:50 PM)Kuch Wrote: agreed, you have to put the narrowband back in the stock location to run correctly with a factory ECU. If you want to use the wideband install a bung in the downpipe about 24" from the turbo.
Ok, as suggested, I have put the factory narrow band O2 sensor back in its location in the wideband is just put off for a later date at this point. The car is still running poorly. It's just so strange how this coincidentally happened at the same time. So it's acting like it just doesn't want to accelerate and it just flat out won't go over 4,000 RPM if I back the throttle off and kind of feather it I can feel it like start pulling every once in awhile like it's supposed to my fuel pressure is good it just sure seems like an ignition issue I just replaced all wires and cap and rotor and plugs the only thing I didn't replace was the coil any ideas where to go first or from here
It I will make the first guess. I actually drops to zero it doesn't hold it which makes me think the little s hoes or whatever that's called the little is right off the pump in the tank is split there check that tomorrow? Is that sound reasonable?
Kuch
Sep 2016
Manlius, NY USA
Was it running fine before the wideband install? If so, disconnect your battery and let it sit for like 15 minutes to reset the ECU. Hook back up and let it run at idle till it warms up, if running better, go for a ride and let it re-learn the system. You could have a bad hose on the fuel pump, but try the battery first.
