BabyBlueBird
Jun 2021
Havre De Grace Maryland
Any recommendations for a air filter that will fit over the stock vam? Doesn’t have to be anything fancy.
K&N 6' cone. (Part #: RE-0930)
88chickentc likes this post
I used an K&N RB-0900 because it was a little smaller. It barely fit over but it did go on.
(01-20-2022, 12:56 PM)Kuch Wrote: K&N 6' cone. (Part #: RE-0930)
Kuch: does it fit cleanly underneath the VAM/air cleaner mounting bracket? Or is modification required?
1931 Deluxe Coupe
1949 Club Coupe
1951 F-1
1971 Torino GT Convertible
1988 Thunderbird Turbocoupe
88Slowbird
May 2019
Tampa, FL
02-18-2022, 08:03 PM
(This post was last modified: 02-18-2022, 08:03 PM by 88Slowbird.)
I used AEM 21-2036DK its a non-oiled filter and easy to clean
not really a fan of K&N oiled filters on anything lol
Pulling hot under hood air into the engine isnt the best idea. Put the filter in the fender, in front of the core support. etc.
(02-18-2022, 04:18 PM)88chickentc Wrote: (01-20-2022, 12:56 PM)Kuch Wrote: K&N 6' cone. (Part #: RE-0930)
Kuch: does it fit cleanly underneath the VAM/air cleaner mounting bracket? Or is modification required? I basically followed the directions in this link, it works very well, it does take some finagling to get the clamps, hose, elbows, and air filter all together and in the fenderwell, but it does work well. https://turbotbird.com/thread-k-n-front-mounted
