w60
Dec 2011
Birmingham, AL
w60
can anyone tell from the video if there is to much play in the rear bearings/axle.
https://www.youtube.com/watch?v=iYtgzZG7klU
Thx
W
Looks typical to me.
That is not bearing wear, that is free play in the axle and this normal to me. 8.8s hold the axles in using C clips in the center section so this results in a little bit of float when you push/pull on the axle flange. The rotational free play is the stack up of the tolerances between the axle, side gear and spider gears in the differential, and it looks normal.
w60
Dec 2011
Birmingham, AL
w60
