I saw it mentioned somewhere on this website in the past but, I don't remember where. Can any direct me to a vendor that sells dash caps for the 87-88 t-birds. The type you glue to the existing dash pad. Thanks, Mitch
Dan E
Greensboro, NC
www.dashcaps.com
Dan Eaves
Dan Eaves
philS
Bellingham, MA
or www.dashtop.com has them too
Enter 433 as the part number to search
They are $99
86 TC, 73 Austin Mini, 72 Austin Mini Van
Click here to beat a ricer.
Thanks for the help, Mitch
