Almost 100 miles today no problems. Going to drive the wheels off it
(06-10-2021, 09:03 PM)Lynski214 Wrote: Almost 100 miles today no problems. Going to drive the wheels off it
Kudos to you on being able to find and fix the brake problem so quickly.
Take a look at the FAQ in the link Rob sent you about modifying the headlamp system to add a relay and thus take the major stress off the ignition switch. If that part goes bad it’ll ruin your day the first time it happens, you’ll be wondering what the &^%$ happened.
