firebirdparts
Dec 2017
Kingsport, TN
I guess you all know better than I that A.P.E. discontinued their install kit for Walbro 255 into Thunderbirds. I find a lot of fuel pumps are still available as ordinary auto parts, including of course the walbro. I do see that Carter, Delphi, and Airtex all make an assembly for this. Do you all think this stuff actually fits? Just curious for future reference, really. The car is pristine, so I would not be terribly worried about putting in a bare pump.
I did some searching on this site and I noticed from the archives that the OEM pumps supplied to Ford were Walbro 155.
Have any of you guys had any trouble with the fuel pump relay? I feel like, based on the noise, things are a bit abusive.
Thank goodness Mustangs exist. That helps a ton with these things. If the pump hanger is rusting apart I guess I'll be singing their praises.
BradM
Dec 2020
Barrington, Illinois
I just put a Walbro 255 in last Fall. See part VPN-GCA719-2 on Summit. I don't remember any problems fitting it. Reuse original sock. Works great.
Did the same as Brad says. I bought a Walbro 255 for a Mustang, reused my inlet screen and fuel hose. Perfect fit otherwise and quiet. Also, I'm pretty sure that the stock fuel pumps in our TC's is only an 80 or 90 pump. Either way, a new Walbro 255 will be a perfect replacement.
Same here,,walbro that was on a fox mustang
Some Walbro pumps tend to get noisy after some use, but from what I have heard and read, the noise doesnt have any significant impact on the life or output of the pump. My Walbro 255 is getting a little noisy, but I am not too worried about it.
Stock TC pump was a whopping 88 LPH, which was the same pump used in virtually every port injected EFI Ford in the 80s, including the 5.0 Mustangs.
