#11 |
(03-26-2021, 02:51 AM)Daniel T Wrote: I changed mine recently and all it took was a small sledge hammer to pop it out,,I was also thinking in just buying the sn95 complete arms but I didn't.
I wish mine were that easy. I've used a ball joint remover and bent the C-Clamp and also a 20 ton press, PB blaster, and heat and still can't get it out. That's a lot of pressure and force being applied that a sledge hammer can't match. I've never not been able to remove a ball joint before. I can honestly say this is a first. I'm just thankful there's a replacement a-arm that I can use and honestly, in hindsight, I think this was a blessing in disguise. The A-Arms weren't that expensive and I'm also getting new bushings along with a new ball joint. I'm also thankful for everyone's help and advice. Thank you.
