ILoveMyTC
May 2001
Delaware, Oh.
I'm preping my car to be painted. Do the birds on the c-pillar stick on with tape or bolt on? Thanks!
Nick Johnson
88'TC
97'LX
Dan E
Greensboro, NC
Two studs on the emblems with nuts on the inside. Have to remove the interior trim pieces around the 1/4 rear windows to get to the nuts.
Dan Eaves
88TC 5spd, Crower 5.5" Sportsman Rods, Short Wiseco Pistons bored .030" Over, Ported Head with Polished Combustion Chambers, Gutted & Polished Upper, Ported & Polished Lower, Polished T/B, Ported E6, SVO T3 .63AR Turbo, Bosch Bypass Valve, 3" DP w/No Cat, 2 1/2" DynoMax single cat back w/DynoMax Super Turbo Muffler, RR Cam, K&N in Fenderwell, Gillis Boost Valve, Centerforce I Clutch, Removed A/C, Polished Wheels, Polished Valve Cover, Polished Crank and W/P Pulleys, Walbro 255LPH HP Pump, Kirban Adj FPR, and the DAMN Heater Core is new too !
NATO MEMBER (Vice Chairman...if it's a vice...I deal with it)
Dan Eaves
