nunnaro
Jul 2020
Long Island NY
How do you access that portion of the website that shows all the topics?
ABird
Mar 2011
Myerstown, PA
(12-27-2020, 06:15 PM)nunnaro Wrote: How do you access that portion of the website that shows all the topics?
Hi, not sure what you are looking for, but you can use the Search to find a topic. Let me know if that helps.
AES
nunnaro
Jul 2020
Long Island NY
I'm looking for the area that shows the problems (areas are broken down, electrical, fuel etc) then it gives the symptoms and the fix. Search won't get me there but an article was sent with a link to the site and I can get it through there. Thanks for replying.
nunnaro
Jul 2020
Long Island NY
By the way it was sent from Jeff K. If that helps.
Mikey97D
Jan 2018
CONNECTICUT
On the Home page here there is a section called FaQs: https://turbotbird.com/forum-faq
The old forum had a different webpage listing everything and some of those links have been lost within:
https://turbotbird.com/old/techinfo/techarticles.html
https://turbotbird.com/old/technical_articles/
https://turbotbird.com/old/faqs/
I use those links often because they lost some formatting when transferred to the new forum. No fault of Andrew just how it goes with a migration.
