New Home for Turbo
BJL Offline
Moderator
The past year we have been full force into buying our own home.
of course we have to have a garage of some sort.
luckily after months of searching and numerous times be out bid in this housing market. we purchased our new home.
https://imgur.com/soFVDhr
The garage is a 24x24 detached. needs some work. but is perfect for what i need it for.
https://imgur.com/35wW0Ng
https://imgur.com/ckKbnzm
https://imgur.com/nfCGMAR
then finally got the sshrine in our bedroom fixed up haha
https://imgur.com/yCbYsEU
its a start and hope to be working out there soon. but first we have to look into some thing to fix and change in the house
Brian Larkin
88TC 330,000 miles
Slightly Modified
gtbird Offline
Congratulations, good luck and make some new memories!
Congrats on the new house, Brian!!!
Rob H Offline
That's a good looking spot, and a nice looking cougar too!
Mikey97D Offline
Congrats on the new place! Nice to have a garage with fall and winter coming.
Way to go Brian. Start making some good memories.
(09-22-2020, 08:19 PM)BJL Wrote: The past year we have been full force into buying our own home.
Hey at least you HAVE a garage! As a former apartment dweller whose Turbo Coupe was parked in a carport with 2 other vehicles, I can vouch for that. Kind of hard to do serious car work when you have to put everything away at the end of the day. We got our house 3 1/2 years ago, don’t know how I did without a garage before.
Some of my best early memories of that time were putting up the pegboard and hanging up the tools, finding a good workbench, getting the work area ready, etc. Best of luck, I hope you enjoy it as much as I did.
BTW, have you heard of a product called Pull It Out? It’s a white liquid that you pour onto oil stains on cement or concrete, wait a few minutes until it dries (it turns into a powder), then you just sweep it up. Stains are gone! (Some might need another application.) A bottle of it was waiting in our garage when we got the house. Amazing stuff.
BJL Offline
Moderator
Brian Larkin
88TC 330,000 miles
Slightly Modified
andrewjs18 likes this post
Mikey97D Offline
That garage floor looks pretty clean and being a detached would make it easier (not easy) to acid etch and treat the concrete while you can. A friend of mine just redid his garage and the materials alone ran about 2k for the epoxy approach but came out beautiful. Just a thought.
Mine's a wreck.
When we bought our current house 31 years ago, the wife insisted on a detached garage. Her reasoning was that if I started a fire while welding, grinding, torching off old rusted bolts, etc, etc only the garage would burn down and the house would still be intact. I only started one small fire in 31 years while stick welding some 1/4" thick plate steel.... some dry leaves had blown in the garage that I didnt notice, and some stray sparks (weld splatter) started the leaves on fire. Didnt even need my fire extinguisher.... just stomped the small fire out.
