PRC Riding rough
88turbomajor Offline
Hi,
I'm brand new to the T-coupe scene and am noticing that when My PRC is in auto, the car rides ok, but the light has started flashing and 2), when the PRC is in the firm setting, some of the shocks ride firm and one just bounces up and down.
Is it worth fixing the PRC system, or just put some nice shocks and struts on, unplug the system and call it a day?
Any suggestions?   Type of front struts/shocks to use, and what type for the rear.
thanks!
Mikey97D Offline
The one shock just bouncing up and down does not sound good and may not be repairable. You can read through this link a little bit about the system: https://turbotbird.com/old/faqs/#Program...20Problems
If you decide to replace the shocks there are better options from the mustangs than Thunderbird. The rear shocks on the Thunderbird are longer so you will need to get brackets that can be found on https://tbirdcougarparts.com/
If you are going to replace the shocks/struts I would suggest doing some searching on here what others have already done.
andrewjs18 likes this post
Code 2 indicates one of the PRC rotary actuators (I forget which one off hand, but I THINK it is the driver side front) either is not switching properly or the internal switch is not telling the PRC computer the actuator has switched. From your description, it sounds like one actuator is not switching. They can get gummed up internally, but can be taken apart and cleaned up and repaired. I THINK there is a list of the PRC actuator codes somewhere in the tech articles, as well as a description of how to repair them.
Mikey97D Offline
(07-08-2020, 11:02 PM)Jeff K Wrote: Code 2 indicates one of the PRC rotary actuators (I forget which one off hand, but I THINK it is the driver side front) either is not switching properly or the internal switch is not telling the PRC computer the actuator has switched. From your description, it sounds like one actuator is not switching. They can get gummed up internally, but can be taken apart and cleaned up and repaired.  I THINK there is a list of the PRC actuator codes somewhere in the tech articles, as well as a description of how to repair them.
The codes are in the link I put up above.  I believe that list was written by you in the tech articles.
(07-08-2020, 02:15 PM)Mikey97D Wrote: The one shock just bouncing up and down does not sound good and may not be repairable.  You can read through this link a little bit about the system:  https://turbotbird.com/old/faqs/#Program...20Problems
thanks for the info!  I'll look around more.
I'll look into it.  Thank you!
Hi, in the article it said to squeeze the white clips to remove the actuator from the top of the shock.  I can't seem to find the white clips to remove the actuator. I see the metal retaining clip and can get to that....
See pic.
Attached Files Image(s)
The white clips are on the PRC actuators on the rear shocks only. Have a look at the top of the shocks in the trunk. The white clips are attached to the PRC rear actuators by the same 2 Phillips screws you see on the front PRC actuators.
To remove the PRC actuators on the front struts, simply remove the 2 Phillips head screws in your pic. Actuator comes apart by prying up the tabs in your pic with a small screwdriver. To put it back together. Use a vise grips to compress the tabs back in place.
When testing the actuators with a 12 V power supply, battery, etc only energize them for a second or less. Applying 12 V for more than a few seconds will burn out the magnet coil.
Hi,
Was able to take them off and I don't see all the Goo folks are talking about......just a little rust on the outside of the winding.....sending pic.
Also, Can I drive the car with these both off of the front?
thanks!
UPDATE: I cleaned the contacts at the bottom (curved metal contacts) and sanded the rust off of the stator. There was a little black goo if you will.
I put them back together and put them back on the car. No change. In AUTO mode, the light still blinks.
I'll try to
Use a DMM an ohm out the rotary solenoid coils ( should be just a few ohms, and use a 12 supply, battery etc to briefly energize the solenoid and see if it rotates 90 degrees or so. Switching the polarity on the 12 V supply should make the rotary solenoid rotate the other direction.
Also use a needle nose pliers to rotate the actuator on the top of the strut / shock. It should rotate easily. If it doesnt, a drop or 2 of oil down the actuator rod hole may free it up. I had to do that several years ago on one of my front struts, and the strut has been working fine since.
2 Guest(s)
