Kuch
Sep 2016
Manlius, NY USA
Wow, very nice looking, they look really stock in the there. Nice work
John B
Dec 2015
New Jersey
Does anyone have more information on what you did to attach the projector and shroud to the headlight housing. I just picked up this same HID and projector set as well as some headlight center sections. I have some ideas but would like to know how you guys have done it. Thanks!
andrewjs18
Aug 2012
Philadelphia, PA
(10-12-2020, 04:01 PM)John B Wrote: Does anyone have more information on what you did to attach the projector and shroud to the headlight housing. I just picked up this same HID and projector set as well as some headlight center sections. I have some ideas but would like to know how you guys have done it. Thanks!
I believe the area where the factory bulb gets installed needs to be widened and then you just epoxy the new stuff in, I think...
BJL did mine, perhaps he can chime in.
