andrewjs18
Aug 2012
Philadelphia, PA
05-18-2020, 09:30 PM
(This post was last modified: 05-18-2020, 10:57 PM by andrewjs18.)
andrewjs18
Aug 2012
Philadelphia, PA
Nice man, does it matter how far from the lens the LED's are mounted? Meaning, does it effect the pattern at all based on the difference in spacing? Also, how do you make the adjustments that you talked about? Nice write up.
andrewjs18
Aug 2012
Philadelphia, PA
(05-18-2020, 10:33 PM)Kuch Wrote: Nice man, does it matter how far from the lens the LED's are mounted? Meaning, does it effect the pattern at all based on the difference in spacing? Also, how do you make the adjustments that you talked about? Nice write up.
this tutorial talks about HIDs, not LEDs. I don't think you can adjust where the HID bulbs are placed - they clip into place in the projectors, iirc. as far as making adjustments, I think things get locked down with epoxy once you get the positioning and such set.
Your right on that, I think I got LED's in my head changing bulbs lately.
andrewjs18
Aug 2012
Philadelphia, PA
(05-19-2020, 01:07 PM)Kuch Wrote: Your right on that, I think I got LED's in my head changing bulbs lately.
I don't think you can adjust how an LED is positioned in our housings...if you buy a 9004 LED, it should lock into the existing bulb socket.
50RACER
Jan 2010
Manassas, VA
What do they look like at night as facing the car when the lights are on?
87 TC Medium Canyon Red
88 TC Black Beauty
BJL
Williamstown, New Jersey
ill post pictures shortly, they are to big to attach
Brian Larkin
88TC 330,000 miles
Slightly Modified
andrewjs18
Aug 2012
Philadelphia, PA
(05-22-2020, 11:29 PM)BJL Wrote: ill post pictures shortly, they are to big to attach
https://imgur.com
the forum will automatically resize them to fit the page.
BJL
Brian Larkin
88TC 330,000 miles
Slightly Modified
raingram70 and Mikey97D like this post
