1988 T-Bird turbocoup engine rebuild questions
TnScott Offline
hello,
I'm new to the forum and hope im not putting this in the wrong place. (I apologize if so)
Im going to Tuesday to pick up a 1988 T-Bird turbo coupe 5 speed that I recently purchased. Ive never had ANY dealings with a Turbo car. I gave $800 for car. The Body is straight with a little surface rust but nothing major. The car is missing the Turbo. I had thought about doing a 5.0 swap, but then considered just sticking with the 2.3. Im not really looking to be a racer just a nice cruiser with some kick. I don't mind performance mods, I just don't want to sacrifice dependability.  Car has 140,000 and something was wrong with the Turbo and was parked. Its been sitting for over 4 yrs.
I guess I just need to know where to find a turbo  and maybe a route to follow to make it a nice fast yet dependable cruiser? Ill post some pics after I get it.
Thanks in advance
Scott
brokenbirdy Offline
(04-25-2020, 11:18 PM)TnScott Wrote: hello,
Thanks in advance
Scott
I just recently installed a new motor/trans in my 88 and I went with this turbo. https://www.ebay.com/itm/T3-T4-T04E-V-BA...Swr05d1kko. I also installed a manual boost controller. https://www.bing.com/videos/search?q=how...ORM=VDQVAP
88 Turbo Bird 5 speed, Intake and exhaust mods, T3/T4 hybrid turbo at 20 psi, Cold air cone filter, manual boost controller, subframes. Still being refreshed.
TnScott Offline
brokenbirdy Wrote:
TnScott Wrote:hello,
Thanks in advance
Scott
TnScott Offline
Thanks So much I appreciate you replying. Have you got to run it any?
Thanks Scott
(04-26-2020, 06:51 AM)TnScott Wrote: Thanks So much I appreciate you replying. Have you got to run it any?
Thanks Scott
Welcome, Scott, to our Forum! There’s much information available here, either by posting a question “live” or searching through past posts.
There has been much written about the differences between Warner IHI and Garrett T3 turbochargers. The IHI was standard on most, if not all, 1987-88 Turbo Coupes. VERY generally speaking, the IHI spools up a bit faster but also tops out lower; the T3 takes a second longer to hit full boost but has a higher top end.
Minor modifications will likely be required if you have one and wish to convert to the other. Use the Search feature here for more information.
Myself, I like to keep my TC as stock as I can. I still have all the original features, like the ABS and the PRC (Programmed Ride Control). Many here have modified either or both to a more modern/less troublesome system (i.e. standard brake booster instead of the ABS, and regular shocks instead of the PRC ones). I have modified the audio system to something much more modern and upgraded to a Gillis boost control valve for better boost control.
brokenbirdy Offline
Thanks Scott
Yes, I have driven it around the neighborhood back roads a bit, got on it in second and boy did she come alive.
TnScott Offline
brokenbirdy Wrote:
TnScott Wrote:Thanks So much I appreciate you replying. Have you got to run it any?
Thanks Scott
Cool, I may have to try one.
A quality turbo will not sell for $125. No matter how pretty it looks, the poorly made stuff from China will not last. A good quality new or correctly re-manufactured turbo will cost 4x that absolute minimum. Back 2001, I paid $650 for a high quality T3 turbo, and do not regret it. Over 100K miles on it boosting up to 24 psi, and it still performs like the day I installed it. I wish you luck with your $125 turbo, but dont be surprised if it performs poorly, leaks oil into the intake and/or exhaust, and completely fails in under 10K miles.
Entropy1988 Offline
I agree, stay away from the junk from China. You'll end up doing the job twice since it will most likely fail in a short time.
