I searched on here and didn't see anyone post about any phenolic spacer for the intakes on our cars. The turboford site has some talking about it and they say it does keep the intake cooler than not using one. I now that wood is the best at insulating and should work fine in our cars as we have only air blowing through the intakes. Has anyone tried making one, either wood or phenolic and had any luck with it? I was thinking of trying one out between the lower and upper.
(04-21-2020, 11:51 PM)Kuch Wrote: I searched on here and didn't see anyone post about any phenolic spacer for the intakes on our cars. The turboford site has some talking about it and they say it does keep the intake cooler than not using one. I now that wood is the best at insulating and should work fine in our cars as we have only air blowing through the intakes. Has anyone tried making one, either wood or phenolic and had any luck with it? I was thinking of trying one out between the lower and upper.
Just to be clear: do you mean between the two halves—the upper and lower intake manifolds?
Interesting thought. I don’t have a spacer, nor did I consider one before.
Looking at the Ford Shop Manual, there doesn’t appear to be a gasket or spacer between the two halves. None that I see mentioned, anyway.
Anyone else have any thoughts on this?
I have had a phenolic spacer between the upper and lower intakes on my Tbird 5.0 for years. I am pretty sure it keeps the incoming air cooler, but didnt really notice much if any performance difference. One thing the spacer did to is allow me to put on some taller polished aluminum really nice looking taller valve covers.
Mikey97D
Jan 2018
CONNECTICUT
When I took mine apart last month there were gaskets between the upper and lower (head and throttle body too). I replaced them all when reinstalling.
If you have a fmic I could see adding a phelonic spacer being beneficial although I am not sure how much you would gain. It would be nice to take temperatures of both with a laser temp gun before and after (don't forget to record ambient).
Is there enough room under the hood to use a spacer?
Yeah, this is just something I wanted to mess around with and see. The Turboford guys have used them on a few different cars. One was an autocrosser and he found his times got more consistent while using one as the intake didn't get heat soaked as much. Some used one between the head and the lower, thus also giving the option of eliminating the water passage to the intake. If doing this, one would have to move the ECT sensor somewhere else, but they did say it worked at keeping the whole intake cooler. I know, this is trivial, but you know how we can't leave well enough alone on these cars. I have a FMIC going on this summer as well, so the stock TMIC will get removed and give me more room without the duct work.
