Center panel gauges..
I finally got to mounting up my gauges in the EQ section of the center panel. I used a piece of sheet plastic like used in model cars and mounted them to the panel itself. I know many have them mounted to the dash and trimmed the panel to fit, but I wanted to be able to easily access the wiring and lights if needed. I soldered up the positive and negative wires so I can run them as one to a power source.
Mikey97D and 347BIRD like this post
(03-27-2020, 10:05 PM)Kuch Wrote: I finally got to mounting up my gauges in the EQ section of the center panel. I used a piece of sheet plastic like used in model cars and mounted them to the panel itself. I know many have them mounted to the dash and trimmed the panel to fit, but I wanted to be able to easily access the wiring and lights if needed. I soldered up the positive and negative wires so I can run them as one to a power source.
That is a VERY nice setup, Kuch! Great job! I especially like the thumb nuts you have on the terminals, very old school.
347BIRD Offline
Good work! I did the same on my last bird and I loved them! I had used a gauge pod from an Audi Quattro that I got out of a junkyard.
1988 Blk T-Bird, 5-spd, Raven int, 3G Alt, K&N conical, Boost controller, ported E6, ported and polished IHI @ 16 psi, 03 Cobra wheels, 255/40/17, 275/40/17, SN95 BBK lowering springs, SN95 Koni struts and shocks, Maximum Motorsports C/C plates, SN95 BMR tubular A-arms, Aluminum driveshaft, LED's, 255 LPH
Kristwitch Offline
oooo Daisy chain. I have this gauge pod that is made to fit into a single din slot but it needs some mods to work correctly in the EQ spot.
1985 Turbo Coupe:  H&R Race springs, Bilstein HD's, BMR Tubular A arms, Aluminum Driveshaft, Serpentine Belt swap, 3G 130A ALT, Denso A/C swap, Ford Motorsports I/C kit
1984 Mustang SVO - Sun Beaten
1985 BMW 745I
1989 Ford F150
1990 Geo Metro
1993 Geo Metro
2000 Ford Expedition
I made a plexiglass panel painted flat black to mount 3 gauges in the EQ slot many years ago. I put an Innovate Motorsports digital A/F gauge, oil temp gauge and battery voltage gauge plus 4 LED indicator lights for various functions in the panel. I also have boost and fuel pressure gauges on the driver side A pillar.
Kristwitch likes this post
andrewjs18 Offline
I used the standard Autometer 2 1/8 gauges
Mikey97D likes this post
Mikey97D Offline
I really like the layout, Kuch. And it looks great in the dash from the other post with the needles getting painted.
I recently picked up a AFR gauge (AEM) and noticed you have a mechanical gauge with the AFR. I wish I had the foresight to think about the mechanical versus digital gauge for the AFR. Was this an easy conversion or did I make a mistake with my wideband purchase?
Mikey,
I bought a complete Autometer 3370 wideband kit when I did mine, nothing to convert. I looked at the digital versions like the AEM, and while they are very well rated, I found it much easier for my eyes to track a single needle as opposed to lights bouncing around. I don't believe there are any other analog wideband gauges out there except for the Autometer.
https://www.autometer.com/2-1-16-analog-...-comp.html
My Innovate Motorsports WB has both a pseudo analog LED ring around the outside and a 3 digit fairly large easy to read digital display in the center of the gauge.
