Picture of 88 TC Fuel Sending Unit
John B Offline
Does anyone have some pictures of the 88 TC fuel sending unit. I’m curious about the plug connection and location of the float. Thanks!
88 Turbo Coupe: Front mount intercooler, MGW short throw shifter, full coilover conversion, tubular control arms front and rear, svo front brakes, vacuum assist brake swap, manual steering swap, GT35R turbo with external gate, pimpx ecu, 60lb injectors, 3 core aluminum radiator, Boport 1.5 cam, gutted upper, corbeau fixed back seats, and the list goes on.
ABird Offline
Here is mine, missing the float.  The float pictured is from Summit Racing.
.doc   TC Sending unit.doc (Size: 1.36 MB / Downloads: 143)
AES
John B Offline
ABird Wrote:Here is mine, missing the float.  The float pictured is from Summit Racing.
Thank you ABird! So my next question is that the fuel pump sits off a separate hangar correct? Does the fuel pump hangar also have a two prone connector? Thank you again
ABird Offline
Yes, separate hanger and 2 prong connector, pictures attached of pump and tank.
.doc   Fuel pump and tank.doc (Size: 1.79 MB / Downloads: 123)
AES
John B Offline
Thank you again ABird; these pictures have been more than helpful. What is the hole in the tank between the fuel sender and pump hangar?
84TBirdTurbo42 Offline
small hole is the sender, big hole is the pump.
Chris Perry
1984 Ford Thunderbird Turbo Coupe. Dead, NY rot killed her
1986 Thunderbird shell, swapping parts from the 84.
John B Offline
84TBirdTurbo42 Wrote:small hole is the sender, big hole is the pump.
Thank you; I do know that but there is a third small hole in between these two. I'm guessing it's some sort of vent? Also, I received my new gas tank yesterday and when looking on the inside of the tank there appears to be a bowl on the bottom below the hole for the pump hangar. I'm guessing this is some kind of baffle that the pump/sock combo sits inside? Can anyone confirm this? Thanks!
Correct about the "bowl" baffle...... it is there to keep fuel at the pump when cornering / braking / accelerating hard.
ABird Offline
The fuel tank vent valve is the small hole in the middle.  I was able to order one for my new tank.  Here is the part number, E7DZ-9B593-A.  I also replaced the gas tank breather valve seal, fuel tank straps, fuel filler neck seal, fuel filter and fuel line clips.  The new tank came with the lock rings and O rings.
AES
