ABird
Mar 2011
Myerstown, PA
Excellent, thank you. I'll measure the resistance.
AES
ABird
Mar 2011
Myerstown, PA
(03-03-2020, 06:00 PM)ABird Wrote: Excellent, thank you. I'll measure the resistance. Chris, Did you get the Mustang sending unit to work? I got mine to work with just the new float. The car is back on the road.
AES
Cracker137
Oct 2009
Carleton, MI
I used the one from LMR, and i worked like a charm, no issues, no modification required.
Mikey97D
Jan 2018
CONNECTICUT
(05-05-2020, 11:41 AM)Cracker137 Wrote: I used the one from LMR, and i worked like a charm, no issues, no modification required. That sounds good. Could you provide the part number or a link to the one you used from LMR? Thanks!
84TBirdTurbo42
Jun 2006
Angola NY
ok guys, sorry i'm just circling back to this. Ive had had a myriad of issues with fuel lately. My tank that sat for 12 years took out my new walbro. i tried cleaning it 3 different ways, and new gas loosened up all the junk in the tank. so, i'm on to a new tank, fuel pump and back to the sender.
I know it will sure not be a perfect accuracy, but in reality, fuel gauges aren't anyways. But i bought this part:
https://lmr.com/item/LRS-9275A/Mustang-F...Unit-83-86
then just bent the arm until i felt it would be most accurate. remember, gas tanks don't fill to the top. so i went a little past 3/4 of the tank "full" capacity. as the full mark.
Chris Perry
1984 Ford Thunderbird Turbo Coupe. Dead, NY rot killed her
1986 Thunderbird shell, swapping parts from the 84.
