I am making my own wiring harness and need some help.
On the exhaust sensor there are three wires with a black one in the middle and a white wire on each side of it.
The wiring diagram shows there should be a black with white wire that goes to battery negative.
Also showing a light colored ( very light green possibly) that goes to the ignition switch. I assume that goes to battery positive.
And thirdly, there is a dark green with light green wire that goes to pin # 29 of the ECU.
I believe the middle black goes to battery negative but which of the whites goes to the pin #29 and which to the ignition switch.
I don’t have a car here as reference so if anyone can help I would sure appreciate it.
Thank you,
Cullen
Thank you,
Cullen
