turbogirl
Oct 2002
hillsborough,nc
okay heres another one it is more like a what in the world question.when i run my foglights for an extended period of time my headlights start blinking on and off.i turn fog lights off and they stopp.my parkin lights never blink just the headkights and it doesnt do it when running high beams.my foglights dont even come on when i use high beams.anyone with any info i would appreciate it.i plan on replacing the factory foglights here soon!!!
friends dont let friends drive imports
87 turbocoupe
87 turbocoupe
the tbird version of christine!!
Two problems here: First, a crappy design by Ford that routes the high current for the fog lights thru the light switch instead of using a relay like they should have. Second, the light switch has an internal circuit breaker (cycling type) for the headlight circuit that gets weak with age and cycles on and off with high current loads.
Several solutions: Best one: replace the light switch, and rewire the fog lights so they are turned on by a relay, which greatly reduces the current flowing thru the light switch. Next best: Rewire the fog lights so they are turned on by a relay, which greatly reduces the current flowing thru the light switch, but keep the old light switch with its old, weak circuit breaker. Worst: just replace the light switch, and wait for the problem to happen again.
[This message has been edited by Jeff K (edited 11-06-2002).]
There is one more solution that Jeff didn't mention. Get new headlight lenses so you don't have to use the fog lights [Image: biggrin.gif]
"The nice thing about each new day is nobody ever used it before" Barnaby Jones
turbogirl
Oct 2002
hillsborough,nc
yeah we got the new headlight lenses when we first got the car.i like fog lights.we are probably just going to replace them with some newer ones and do away with that switch and wire them up like jeff said!!!thanks to all
87 turbocoupe
[This message has been edited by turbogirl (edited 11-06-2002).]
87 turbocoupe
Kev
Harrison Arkansas
Kev
dimmer switch will cause what you are talking about, I've had to replace the dimmer switch (on the column) on both TCs that I've owned. Same exact symptoms as you describe, and it fixed it both times.
The other guys didn't mention though, the fog lights aren't supposed to work with your bright lights on. I'm not positive, but I don't think they do on any type of vehicle. Can anyone oppose this?
Kev
1988 TC 5spd
segfaultxr7
Cape Coral, FL
Kev, I think there's a law specifying that you can't have more than 4 forward-facing lights on your car. High beams count as four, probably because the law dates to when cars had two sealed-beam lights per side and the high beams turned all 4 on.
88 TC 5-speed
BJL
Williamstown, New Jersey
if your high beams ar3e on do you really need fog lights?
Only reason i ahve my fog light son all the tiem is 1) the come on with igniton, 2) i ahev old elenses and cant see sh*t, 3) i think they make the ca rlook aggressive, not statin ti has a 4 cyl, he he, surprise!
Brian J Larkin
1988 Turbo Coupe 5spd, dark blue , bought form junkyard with blown motor, dropped used motor in drove it for a year, repaint and body work by me, since owned done three head gaskets, 4 clutches, 2 motors and two turbos, one thing about this car, i keep fixing it , it must be the members of this board, always there to help! Thanks guys!
I got tons of spares parts I’m trying to get rid of email me with needs , I sell cheap I wanna get rid of it now
http://crazydriver358.5u.com
Brian Larkin
88TC 330,000 miles
Slightly Modified
