TheRedhead
Feb 2002
Willow Grove, PA USA
Shouldn't this be an easy thing??? Why do these cars have to be so difficult?? Changed dist cap and new plugs. cranks and backfires and won't fire up. Stupid really, it's probably something so god awful stupid. I should be doing my nails instead of working of cars [Image: smile.gif]
Matuszak88tc
Oct 2003
Holloman AFB
Go to a Autozone and get the T-Bird book for your car, In the tune up section look for a picture of your distributor cap and see if maybe you got one of your wires crossed. if that isn't it recheck you plug gap. Hope that I have been some help.
1987tc
Bicknell Indiana USA
It sounds like you have the firing order wrong on the plug wires. Did you have all the wires off at the same time?
If you have a Motorcraft cap it should have a small number "1" near one of the wire towers. A lot of aftermarket caps also have it. The distributer rotates clockwise just follow the rotation around the firing order is 1342. Hope this helps.
Wes
1987 TC:
Hurst compition plus shifter,K&N cone,roller cam,custom single exhaust,Gillis valve,H&R springs,KYB shocks,struts and quads.
3.73 rear.
Tubular rear control arms and Kenny Brown trac kit brackets. soon to come, Installation of Caster camber plates and a custom built roll cage.
Linton Indiana
Sold my Turbocoupe. It went to a good home.
turbocoupeterry
May 2001
lima,ohio united states of america
like he said check the firing order 1342 and the number one plug should be the one facing down if your looking at it over the driver fender re hook up the wires and recheck the gap .034 i think try it and let us no
88 tc, new tires and a k&n filter fender mounted
