Hello, what is the easiest access to the starter wiring (from underneath or from above??
I am replacing the starter and am looking for a few tips to make the change out easier.
Thanks alot. The car is an 88 turbocoupe, automatic.
5.0TurboCoupe1988
Apr 2008
Broken Arrow, OK
underneath. if i recall correctly, you'll need to remove one bolt and loosen the other on the k-member brace to swing it out of the way.
1988 TC 2.3/5-Speed, 148K
AllAboutCars101
Jul 2009
suffolk, VA
i actually removed mine to get to a water line to the turbo. didnt remove the whole thing, but its not hard to take off the bolts. shouldnt be too tough, under the car is the way to go. i thankfully, have access to a lift
Easy job. And as everyone else stated from underneath is the only way to go. It is also a good idea to at least loosen the bolt holding the starter wire before removing the starter bolts.
RDOG
Ontario. California U.S.A.
I went to APPEX in vegas this weekend and they had these real nice 90* cable connectors. I might use one next time I do a starter job. Makes it easier to install the + wire. Also I'm considering doing a ranger small starter. Anyone else do a ranger swap yet?
boosted chicken
Jan 2006
Odessa, Texas
I went to the mini starter from a 1993 2.3 Mustang. One extra wire to run but well worth it. Much lighter than the TC starter.
88 TC#1 2.9L tall deck. Essy SVO head, Boport header, BW SX369 turbo, C4 trans, MS2xtra
88 TC#2 drag car project(someday)
88 TC#3 parts car (just needed the header panel...bought the whole car, lol)
